跳转到主内容
Samsung's fitness-oriented smartwatch, featuring a curved super AMOLED touchscreen display. First released in April 2014.
35 个问题 查看全部
问题已关闭
Corrosion on charge point.
Between sweat and water the copper charging spot on the watch has appeared to have corroded. It hasn't caused any issues with charging or anything but I want to find out how to clean it or repair it. Does anyone know of a good way of doing this? I'm thinking of using some isopropyl alcohol.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Why fix it if its not broke right?
Here is the guide for teardown of the Gear Fit.
Samsung Gear Fit Teardown
Once tore down you clean it with some isopropyl alcohol 91% at least.
这个答案有帮助吗?
得分 1
添加一条评论
A short fix as well.... if the gold/copper contacts on the back of the Fit itself are corroding like mine did, use a stiff pencil eraser and rub at the contacts carefully. If you do this before the corrosion sets in too much, you should be able to prevent it, with regular cleaning.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,239
