跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
299 个问题 查看全部
How does the Ipad Air screen replacement digitizer cable fold and glue
Hi Guys
How does the Ipad Air screen replacement digitizer flex cable fold and where does the adhesive on the flex cable stick down? I can't find the information anywhere, would you be able to post a photo how this is done on a replacement screen?
Luke
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
3个答案
最有帮助的答案
Hello Luke, bend the flex as shown in follow picture and sit it in the right place, check more details here: http://www.etradesupply.com/blog/reason-...
这个答案有帮助吗?
得分 4
1条评论:
thanks for this! i've ghosted two replacement screens thus far. my third and final attempt is at hand. wish me luck.
完成的
添加一条评论
Hi Luke,
It's a bit hard to explain, but the adhesive from the flex cable should end up sticking to the inside of the frame next to the LCD. When you lay down your new digitizer, you will put down the right side first, pushing the digi cable assembly directly down between the LCD and frame.
We have an iPad air video we recently posted, see if it helps: http://www.amazon.com/gp/product/B00DZXY...
这个答案有帮助吗?
得分 2
4条评论:
Hi Josh, Thank you for the information. The link I can see a product for Tesa 4970 , but no video? Luke
完成的
Whoops, that was the last link I copied. Here is the correct one: https://www.youtube.com/watch?v=2qQn-T-Y...
完成的
I clicked on the link cuz IM having the same issue and it says video is private.
完成的
would have been great to see this video. i've broken two flex cables guessing so far.
完成的
添加一条评论
While I've never broken a flex cable I've resigned myself to the fact that an iPad with aftermarket adhesive holding the digitizer in place will never hold together as well as the factory glue.
I inform people of this before starting the repair and when I hand it back I have kapton tape holding the digitizer in place externally. I usually recommend they get an otterbox style of case to help hold it and to hide the tape.
It sucks, but it's better than a broken iPad.
这个答案有帮助吗?
得分 0
2条评论:
Just a little bit harsh aren't you.
If you actually took the time to read my comment you would see that it was referring to the adhesive that is supplied with these aftermarket screens. I've fixed screens after professionals have already fixed them once and I've seen some interesting repair jobs, not to mention digitizers that have fallen off despite the adhesive and globs of glue that they have use to try and secure them in place.
With that being said, how about you add some positive content to this site rather than join just to put down other people?
完成的
if you use the red double sided 3M tape along the edges of the Digi (as close as u can get it) then just pop some clamps on it and pop it in a dehumidifier for a half hour it should stay down pretty well and if you want to be sure it will never pop out u can use a vacuum sealer that worked very well for me so far
完成的
添加一条评论
添加你的答案
Luke Robinson 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 20
总计 6,489
