跳转到主内容
加入维修社区 - 创建账户
The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
My phone doesn't turn on anymore, I don't know why.
My screen is broken but it was still able to see everything, but one day it just turned off and never turned back on. i bought a new battery and it's not that.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
If you have damaged the screen, you could have possibly damage the LCD with it, try having a new LCD installed on the device and also check to see if your phones On / Off button is working correctly
Regards
这个答案有帮助吗?
得分 0
2条评论:
How much would it cost to get a new LCD? How do i check if my ON/Off button is working?
完成的
You can purchase a screen below from iFixit, the link is as follows; Galaxy Note 3 (T-Mobile / AT&T) Screen
You will have to disassemble the phone and check the flex unit itself, if it clicks and so forth. If there is no click, you will need to clean underneath the silver contact of the button of any dirt that may be under there.
Also make sure your chargers are working and that the battery has at least a little bit of charge inside it.
完成的
添加一条评论
添加你的答案
Ray Salazar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 448
