跳转到主内容
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 个问题 查看全部
问题已关闭
Front panel assembly installation
How clean does the rear case surface (where the adhesives go) have to be? I used rubbing alcohol and q-tips but the surface is still very tacky.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
The cleaner the better. Try using scotch-brite or another metal sanding material. Steel wool may also work. You want the surface to be smooth and clean or else the digitizer will come back up
这个答案有帮助吗?
得分 3
1条评论:
The scotch-brite helped. I also need rubbing alcohol, q-tips, elbow grease and patience. The epoxy was stubborn.
完成的
添加一条评论
I would suggest cleaning it until there is no stickiness. In order for the new adhesive to bond correctly with the frame/housing it will need to be completely clean. Once the new digitizer is seated use some heat around the edges to soften the adhesive then clamp it in place until it sets.
这个答案有帮助吗?
得分 1
添加一条评论
Acetone and Un-Du are my go to when removing adhesives. Goo Gone has some residue left behind. Heat will also be your friend. Sounds like you have the q-tip part figured out. Scuffing will help just remember to clean very well with alcohol after you have all the adhesive up. Dont forget to use heat to activate the adhesive when you put the digitizer back on.
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 74
