跳转到主内容
A lawn mower made by the American Company Toro
119 个问题 查看全部
Why is gas pouring out of the air filter?
We started to use the lawn mower, which was fine last time we used it the beginning of summer. We started pouring gasoline into the gas tank and then gasoline started to pour out through the air filter. We did not spill any gasoline onto the mower. What could be causing this to happen?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
The needle is probably not seating correctly. The most likely cause is a bad float. A carburetor rebuild should fix it. If you’re pretty handy, it’s pretty easy.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 652
