跳转到主内容
由华硕制造的笔记本电脑。
2519 个问题 查看全部
black screen - auto turning on when plugged in
Hey. First of all sorry for my poor english. Here is my problem;
Yesterday my laptop first got dark, like the minimum level of brightness. But it was still working. It happened during I was plugging of the external hdmi cable (external monitor). Then, I tried to rise the brigtness via fn+ f6 (i think). It didnt work. So, I turned it off to turn on again. It didnt work.
When I push the power button, I can hear the hdd's sound. I can see the lights. But never screen worked.
Then I realize that after a little while, the hdd light starts to flashing with a constant time period. Like a car's turning signals.
Then I started to find a solution on net. Lots of ppl said it happens because of static electricty. They say remove the battery, plug off the charger and then hold the power button for 60 seconds.
However, this laptop's battery can not be removed from the backside but the inside. Like %#*@ iphones.
Well, I disassembled it and I did it too. It didnt work again. Then I checked net again. Someone said. Disassembly all of it then gather them again. I did it too.
Then, it was started not to work via power button if it is not plugged in charger. Also, when I plugged in, it started to start automatically.
And other symptoms:
- Dvd rom doesnt work (cant open)
- air mode light is always turned on
- hdd light flashing with a fixed period
- fan (cooler) doesnt work.
And: it is a new computer just came to me yesterday but have no warranty. Dont ask why, it is long story.
Here is a picture of inside:
http://i.imgur.com/hq8kF90.jpg
And otherside of motherboard: can someone tell me, where is the cmos battery?
http://i.imgur.com/SxE7T3Z.jpg
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
I have this problem too. please help
完成的
Hello sir , I have problem in my Asus n53 note book.If I plug the power cord to the pc it automatically truns on and the monitor is blank....before that is was changing my OS.... WILL THERE BE ANY PROBLEM IN MY HARDDISK?????sir please give solution....thank you sir.....
完成的
I have similar symptoms but in my case it was caused by a water spillage. I do wish the batteries were easier to remove in a hurry when such a thing happens. My daughter's Asus in this case, was totally dead after the spillage but after following a YouTube video and baking the motherboard in an oven it now has the same symptoms as above. Anybody else got any fixing suggestions?
完成的
添加一条评论
4个答案
最有帮助的答案
Yikes.
Don’t know if you still have this problem but don’t go changing motherboards or poking around with things just yet.
First, if you know how to use a multimeter, check the power supply for the readings listed on the power supply tag. If you don’t, buy one and watch a youtube video. If that’s not possible, find the same power supply somewhere and try it. There are many on ebay for -+$10 USD.
Secondly, see if the power jack inside the laptop is stationary or has any play or wiggle to it. To do this, remove the battery, remove the power supply and press the power button for 10 or 15 seconds. This just drains residual/stored power from internal capacitors so you won’t get zapped.
Next, using a plastic or wood implement, such as a tooth pick, etc… touch the power outlet of the laptop’s power supply hole and wiggle left or right lightly. Does it move or feel loose? If so, you need a motherboard repair that most electrical or small circuit board technicians can do fairly quickly, most times under $100.
If the power jack in the laptop is not the problem and you’ve replaced the internal CMOS battery inside the laptop as mentioned above, get the laptop to a technician for testing. There are many components on the board itself that can be bad from tiny capacitors to power governing Mosfat’s that are easily diagnosed by good tech’s with a good multimeter.
Good luck to you.
这个答案有帮助吗?
得分 1
添加一条评论
I've had this problem twice with two similar HP laptops. The quick fix is simply replacing the MB. You can also try swapping the battery packs. That's to know isolate the problem. If it can power up you are lucky. Just restore the BIOS or replace CMOS and reset BIOS. Voila...
这个答案有帮助吗?
得分 0
1条评论:
How is replacing the motherboard "simple" This problem isn't "simply" anything. Don't jump to "simply" replacing the motherboard. There are a handful of reasons your machine may be doing this, the "simplest" being the BIOS has a setting in the ON position to: "turn on when AC power is present"
完成的
添加一条评论
Hi,
This sounds like a combination of things. First of all, the minimum brightness sounds like your backlight is no longer functional.
The black screen but signs of the unit being powered on would typically indicate your LCD panel is knackered, supported by the fact the brightness went just shortly before.
The not powering on without a charger being plugged in is likely simply due to the battery being flat. As the screen isn't working, you can't see the battery indicator.
When a laptop's battery is flat, it's common for it to power on automatically as soon as the charger is plugged in, both my laptops do this.
If you want to go down the LCD panel replacement route, I've had good experience getting replacements from AccuPart.co.uk, have used them dozens of times for LCD panels. The actual replacement process is pretty simple, especially as you've already cracked your laptop open once. Just be careful threading the cables, particularly the WiFi antennae, through the hinges correctly or you risk shearing them in half.
Your other symptoms are a little unusual though. The disk tray not working and the fan not working could be symptoms of a dead motherboard, as someone suggested, however as you're cracked your laptop open are you sure you fully inserted the CD tray back in and reconnected the CPU fan cable if you disconnected it? If you're sure, try googling your laptop model plus "hdd light blinking". If this is some sort of error code, you should get a hit for it. Failing that try googling your laptop model plus "error code lights" and see if you can get a list of error codes for your laptop.
这个答案有帮助吗?
得分 0
添加一条评论
mine is hp laptop when my laptop fault, after turning on in a few sec it will automatically shutdown.
I thought that it was a fan or overheating problem, but when I checked the thermal paste but it is okay.
second is the motherboard, there are some portions of IC’s that faulted by a clag water stone it is actually damaged. so that was my final research.. motherboard is the problem./
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
emrullahgazioglu 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 20
总计 8,376
