跳转到主内容
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
How to replace the SIM Micro SD reader
Hello I have a Galaxy S5 and the SIM/Micro SD reader is not working. I was going to replace it but cant find any info. Can you replace the part or it is connected to the mother board.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hello Christopher,
The sim/sd slot on an s5 is soldered to the motherboard. It will require a solerding iron, heat gun, and several other things to change. This would not be a repair for someone who has no soldering experience as you will most likely trash the board. Not to mention you have to pry the LCD out to even open an s5, and thats fairly difficult. I would highly recommend taking it to a professional
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Christopher Roberts 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 120
