跳转到主内容
Repair guides and support for home heating, ventilation, and air conditioning system repair.
348 个问题 查看全部
What does a suddenly louder AC fan (right?) mean?
It started last night: The AC is really, really loud when turned on. This happened last night. Smacking the side of the unit makes the sound normal for a few minutes.
Model: Kenmore 580.75050801
Approximate age 1-2 yrs
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
a louder fan is sometimes a sign for a loose or broken part around the electric motor
parts 8-C and 9-C would be my first guess - but there are other possible parts that could "transport" the vibration
click here for the breakdown
这个答案有帮助吗?
得分 2
1条评论:
完成的
添加一条评论
1) check the motor bearings. Do this buy spinning the fan blades with the DISCONNECT OFF. Is it making a noise? Does it feel like metal on metal?
You can also see if shaft seems to wobble while spinning.
If bearings are bad replace motor.
2) most likely that loud sound is your compressor. Refrigerant migrates into the oil while the system is off. When your crank case heater goes out it may sound rough for a minute while the oil heats up and the refrigerant is boiled off the crank case oil. Check this and get back to me.
这个答案有帮助吗?
得分 0
1条评论:
By* not buy. %#*@ autocorrect
完成的
添加一条评论
添加你的答案
HealthyPizza 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 3,780
