跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
问题已关闭
speaker not working after changing the power flex
Hi folks
I have replaced the power flex on a 4s but now the speaker don't work. Any ideas what the problem could be?
I haven't damaged the speaker the only thing I did was peal it off the old power flex.
I thought possibly the speaker was sitting lower and not touching the mother board so propped it up a little but still not working.
This is the second time this happened to me, the last time i just put a new speaker in and it worked perfect.
thanks in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Is this a four CDMA or an AGM?
It sounds to me like you got the speaker on upside down you might need to turn it around and make sure the two prongs are hitting the leads and if that does not work then you must the damage something in the speaker and removal of the PowerFlex cable or you could a got a bad power flex cable that does happen some Times
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 49
