跳转到主内容
宏碁所制造的台式机的维修和支持指南。
70 个问题 查看全部
memory low mesage but disk is clear
continually getting message about low memory but disk is not full. I have mcfee
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 9
添加一条评论
4个答案
已选择的解决方案
I recommend you increase the amount of RAM in your computer. Today's computers are usually happy with 4 Gb of RAM. If you already have that, increase it to 8 Gb.
这个答案有帮助吗?
得分 5
1条评论:
thx! working!
完成的
添加一条评论
Memory is Memory, storage space is not memory, this may be a case of a failing RAM Chip like @phudson38 eluded to (but let me expand) I would shoot for a new stick of RAM (what windows OS are you using?) if you have a 64 bit version go for 8 GB
这个答案有帮助吗?
得分 2
添加一条评论
Make sure you don't have anything running that shouldn't!
Often a rogue program can chew up your available RAM. Make sure you didn't download any P to P apps or try not to run too many apps concurrently if your memory is on the low side (4 GB). Use Windows Performance Monitor to monitor your RAM usage.
这个答案有帮助吗?
得分 2
添加一条评论
Adding more RAM usually fixes low memory problems. Windows uses a part of the hard drive as "Virtual memory" that it uses as a temporary addition to RAM. The newer versions of Windows automatically control the size of the virtual memory, if you are still on XP or older (recommend upgrading since older Windows is not supported for updates or security) you can increase the virtual memory to help with the memory bottleneck.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
tutu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 1,253
