跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
What adhesive to attach glass to frame in screen refurbs?
For the shops that do their own display refurbishments, what adhesive do you use to attach the new bezel/frame to the glass of the display? I've not come across anything that doesn't make a giant mess when trying to use the adhesive and still does a good job of attaching and doesn't start to lift once installed into a device.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
You can use b700 glue or you can use preglued frames. If you decide to use preglued frames you will need a framing machine. We will be updating more info in our blog therefurblab.com ! Ask us anything!
这个答案有帮助吗?
得分 0
添加一条评论
Try using hot glue. Have to be careful that it does not get into the LCD. Can get it at Walmart.
http://Delcity.dashrepairs.com
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bobby 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 227
