跳转到主内容
Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
115 个问题 查看全部
Backlight filter and diode location on iPad Mini 3 A1599
I've done the backlight filter replacement on ipad minis previously, but now I've got a mini 3 in with backlight issues, and I'm not sure where the filter and diode are on this model. I've identified a couple components (red arrows in pic) that could be the filter, but they don't look burned like they typically do when they're bad, and they both have continuity. I've also found a couple components that could be the diode (blue arrows), but neither of them has continuity either way. Can anyone help me out with where the diode and filter are on this thing?
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
On your image the filter is the first red/pink arrow on the left and the diode is the first blue on the left.
这个答案有帮助吗?
得分 2
6条评论:
If they are okay then it could be a problem with the capacitors around the filter or components around the LCD connector or the LCD connector itself.
完成的
Thanks for the quick answer! Do you know if the filter and diode for the original mini will work for this? I can't find any that specify that they'll work for the mini 3.
完成的
I am pretty sure you will be fine to use the same parts.
完成的
Thanks! I'll try it and post back here with the result.
完成的
Just put the new diode in and the backlight is now working, so apparently the parts are compatible. The filter tested good so I didn't replace it, but I'm guessing that it would be compatible too.
First time I've seen a good filter and a bad diode on one of these backlight repairs!
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Johnathan George 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 7
总计 3,059
