跳转到主内容
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 个问题 查看全部
Are there glass removal instructions for the MBP 15" Unibody?
Hi,
are you able to tell me how i have to proceed to remove the glass from the screen in order to preplace it?
Sommetimes , someone tells that you have to warm up a little bit the border of the glass then pull the glass in the corner with a Suction and a small plastic tool by putting it between the glass and the screan , and sometimes we you don't have to warm glass first .
Thank you for your help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
We have that guide for the 13" MacBook Pro Unibody here (steps 15-22). The glass removal is the same procedure as your machine. Once the glass is off, however, there may be a different orientation (especially with screw locations) for further disassembly.
Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
brice06 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 4
总计 1,419
