跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
No display after routine thermal compound application.
My macbook pro was overheating so decided to open it up and reapply thermal compound to the cpu. That all when smoothly but upon closing up the unit I noticed a burning smell coming from the machine. I opened it up and realised that some components near the lvds had literally come off. I can't find the schematics for this machine and I have spent countless hours hunting and no joy . Its emc is 2554 . Has anyone every had this problem and how did they over come it? Seems a pity to just buy a new one. The machine makes all the noises on startup. Any help would be great appreciated. Cheers
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
The schematic is SCHEM,MLB,J30 your board version is 820-3115 keep hunting !
完成的
Thanks John. Have managed to find the schematic. Will attempt the repair. I have nothing to loose as its dead at the moment. Besides am pretty good at soldering so will give it a bash. Thanks again. All the best.
完成的
添加一条评论
2个答案
已选择的解决方案
Looks like you got components burnt L9004 and C9015 they are on the line of PP3V3_LCDVDD_SW 3.3v but instead of just replacing them you need to find out why and how they burned in the first place it may do it again you probablly broke one off one the components by accident which is a good chance then a simple replace of the components may do the job you need also to take voltage from that 6 legged chip sort of close to the Plink Fuse U9000 also go to capacitor C9012 and see if your getting 3.3v there.
You could alternatively start with replacing Inductor L9004 which is a 402 package @ 120 ohm 1.5amp and cap is a 10uf 6.3v in a 603 package you can get them from digi key or mouser also pins 2 and 3 look a little dark on the lvds connector you may need to inspect and touch them up a bit.
If your really serious about repairing this search a1278 no backlight etc on youtube you find some professionals in action it's 2 part really the hunting troubleshooting and the physical reworking of the board.
这个答案有帮助吗?
得分 2
1条评论:
John,
I have the same/similar issue with a neighboring component. It is the black one (below the brown one) to the left of the burnt area. Can you please help identifying it? I will try to post a picture of it.
Thanks.
完成的
添加一条评论
John,
It is the circled one in the attached photo.
Thanks!
Ibo
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Zane Ali 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 302
