跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
Why the screen is black?
Hi!
I have a problem with my iPhone 5C. I was using my iPhone normaly and i decided to make a little darknes my display, so when i was moving the control of brightness it happens blackout! I restarted my phone many times, even using DFU mode. The problem is that the screen is totaly black and it is without any respond (touch panel also dosen't work). You hear the sounds of Siri, soud of clicking the buttons, but nothing on the screen - ofcourse i replaced the lcd and it is the same. Many times i checed the connectors, but still no solutions. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Try opening the phone up, unscrewing the 4 screws at the upper right corner holding the metal plate in, carefully un-pry the cables, clean them with alcohol and re-fit them. If this does not work, try a new screen.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Adam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 108
