跳转到主内容
加入维修社区 - 创建账户
Mac won't turn on. Not charging properly either
Hi,
My Mac just won't turn. it's a 13 inch air 256gb ssd Early 2014.
I've tried resetting the smc. It did work once and I was able to use it normally for a while. But, after I put it to sleep, it refuses to turn on. It won't even charge. The light on the magsafe is still glowing amber despite being connected for over 8 hours.
There's no response from the device whatsoever. Any advice on how to make it start would be appreciated.
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Avi,
Have you tried turning it on with the MagSafe connected? If not, give it a try as it may be a bad battery. Otherwise if it still doesn't work, you might want to try these: If your Mac won't turn on.
Best of luck!
这个答案有帮助吗?
得分 1
2条评论:
Hi!
Thanks for your response! I've tried turning it on with the magsafe connected, but it still won't turn on. It's completely unresponsive.
完成的
If you're comfortable opening your MacBook Air you can use this Guide to disconnect the battery: 2014年初 MacBook Air 13" 电池更换 and then use this guide to reseat (remove and reconnect) the SSD: MacBook Air 13“2014早期固态硬盘更换 after reseating the SSD leave the battery disconnected for at least an hour and then reconnect it and try to power on again afterwards. Also, just to be sure...do you hear a "Chime" or the fan running at all?
完成的
添加一条评论
添加你的答案
Avi M 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 2,790
