跳转到主内容
加入维修社区 - 创建账户
Samsung NaviBot SR8855 是一款实用的三星扫地机器人。
Short shift and turn.
Navibot sr8855 after repair of FET tranzistors for brush have bad mooving - navigation.
From the beginning it worked well and after some time was problem in navigation.
It looks like that: move 20-30cm stop and go back about 3cm, turn 90st. and repeat.
Sometimes work good for 1 minute and then again fail to this state.
I try test mod and all sensors look fine, motors are OK too.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
I have the same issue. Is there a fix?
由完成的
添加一条评论
5个答案
Hi,
yes, i found that it was dusturbation in system . I add some capacitors on motor and all is OK
这个答案有帮助吗?
得分 0
添加一条评论
Can you describe more precise what did you done?
Could be the aging of the accumulator?
这个答案有帮助吗?
得分 0
添加一条评论
I must replace suction motor and with it start the disturbance of electronics. For this I used capacitors on motor pads. I was 1nF + 100nF + 1uF together. To other motors must be carefull becouse are PWM drivered. There You can use only some smaller - max 100nF capacitors.
这个答案有帮助吗?
得分 0
1条评论:
Hi
What voltage do you use in capacitors?
由完成的
添加一条评论
Can be that the battery started to decay?
这个答案有帮助吗?
得分 0
添加一条评论
It could probably have an effect but it is not a reason.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
smsoftware 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 25
总计 2,314
