跳转到主内容
加入维修社区 - 创建账户
Inspiron 1545 于 2009 年 1 月 16 日发布,是一款 15.6 英寸的入门级个人笔记本电脑,提供 3 GB 或 4 GB 内存版本。它是 Inspiron 1525 的继任机型。
Some portion of motherboard is overheating
When the battery was inserted then the portion 2 inches below the f1 fuse was overheated but when i plug in the power then there was short circuit two inches away from the right side of touchpad and smoke came out...
What happened to it ? And what should i do now?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
At our labs we hook up an external adjustable PSU and slowly increase the amps whilst monitoring with thermal imaging camera for overheating components. Once found we replace them and repeat the process until the board is repaired. Some of the components can also be tested in-circuit, so would suggest testing all diodes and resistors around the area that gets heated up.
这个答案有帮助吗?
得分 2
添加一条评论
solder whatever component that was heating up off the logic board afterwards, plug the charger it again to see if it still heats up.If it doesn't that mean the component you removed was damaged and needed to be replaced.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
nomanghous 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 14
总计 535
