跳转到主内容
加入维修社区 - 创建账户
This affordable large-screen Android phone sports a 5.7-inch display and large 3,400 mAh battery.
Why isn't my Camera working?
Everytime I open it," Unable to connect to camera,Camera has been disabled because of security policies or is being used by other apps" I tried fully reseting the phone but it still won't work. Thanx in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 237
42条评论
Problem started for me this morning. I have tried force close and deleting and have done full phone reset.
完成的
Spoke with tech support was adviser hard factory rest.
1. Power off.
2. Remove SD.
3. Hold power and volume up key at same time.
4. Use volume key to toggle options. Power for selecting.
5. Select "Wipe data factory reset"
6. Select "Yes or confirm"
完成的
But did it work.
完成的
It does work, but u don't necessarily need to wipe data/factory reset as u risk the possibility of losing any data not saved onto your sd card. Simply select reboot system. Your phone will restart on it's own and your camera should be working again.
完成的
Tried all those options & camera still doesn't work. Now what??
完成的
显示更多的37条评论
添加一条评论
22个答案
已选择的解决方案
hold the power key and wait for 1 min than let the power key go . now try updating the phone software to fix if it is a bug . close all background programs and for more please follow Guide -Fix Phone Camera Step By Step and i hope this will help you to fix the camera .
这个答案有帮助吗?
得分 29
7条评论:
So what IM trying to do is fix HSR not supported. So I have a ZTE and it's powered by MetroPCS. And it started a few days ago I tried what they suggested and it didn't work. MY FLIPPING PHONE!!
完成的
at the first try the camera is working without updating the phone software
完成的
I have the zte zmax pro n my camera is not working i did the reset n still dont work what else can i do
完成的
I'm having the exact same problem that they're having please help! I really need my camera!
完成的
显示更多的2条评论
添加一条评论
1. Shut off phone
2. Hold down the volume up button and power button at the same time.. white screen will appear, release power button, then secondary darker screen will appear.
3. Select reboot system.
4. Take your damm selfies or whatever you do.
Yes, it works.
这个答案有帮助吗?
得分 15
11条评论:
Will it delete all my apps
完成的
i am doing this right now
完成的
Yo mama:
Just so u know, I was trying to fix this problem with my phone and was scrolling reading all the solutions... By the time i got to urs I had seen ur solution once before but the way u put it sold me lol. It worked!!! Thanks.
完成的
My Back Camera Stop Working
完成的
First one i tired and it worked thanks :)
完成的
显示更多的6条评论
添加一条评论
I was having problem with my camera and flashlight today, and what I did went to settings, apps, click on camera, Clear data, Clear Cache, force stop, click disable , then click enable and restarted my phone and camera and flashlight worked again.
这个答案有帮助吗?
得分 7
7条评论:
Thank you, thank you, thannnk you!!! My camera and flashlight is back working because of this. I tired everything else people were saying and NOTHING worked and I was starting to give up hope until I read your comment and tried it. Thanks again.
完成的
It works! Thanks!
完成的
What if the disable button is gray and won't let me enable it?
完成的
Thank you so much this was so helpful.. I did everything even a factory reset and nothing happened. The comany for zte zmax even told me they can't help but thanks to you I have my camera back
完成的
Super thank you! You're amazing my camera and flashlight is now working. Its an absolute relief!
完成的
显示更多的2条评论
添加一条评论
You have to got to settings. Then apps. All apps. Camera. Clear data.. no it won't erase your pictures... force stop. Disable. Then restart phone. Then enable camera. And it works. Tried everything else this is the only way I could get it to work. Went through manufacturer and phone provider and they couldn't do nothing or tell me why it happened to two different phone's the same exact day.... best of luck.
这个答案有帮助吗?
得分 2
7条评论:
are there any other ways to get camera working other than the options previously discussed. I've tried everything and came across your post just knowing that this would fix my problem but it didn't... Please help if you any other suggestions...I've also replaced my SIM and SD card and rebooted, full reset, and disabled the camera and still it doesn't work..
完成的
I have tried everything as well! None of these work for me. Aaaaagggghhh life without a camera is miserable
完成的
This is driving me crazy I tryed everything they've said and still my camera's not working
完成的
My daughter put my zte zmax phone in the sink and has water damage, I can do everything perfectly fine but only thing is the camera will not work it won't go on or my flash. Please help
完成的
I did everything people saying to do on here
完成的
显示更多的2条评论
添加一条评论
Factory reset has resolved this issue, backup all your photos videos and contacts before reset.
这个答案有帮助吗?
得分 2
添加一条评论
It is easier than you think(sorry for my English)...you don't need fabric restoration. Probably wen you insert the SD card you set up your camera with it so wen it get filled the error appears . So follow the next steep and you going to get your camera back.
1. Turn off your phone
2. Remove your SD card (use the key that comes whit the phone if apply)
3. Turn on your phone
Open your camera that's it
This is an extra step
4. Insert the SD car (make sure it's clean I mean, you've been removed all pictures and videos and placed on your computer or whatever. Or put a new one)
I did it whit my ZTE ZMAX and works
Hope it can help
这个答案有帮助吗?
得分 2
5条评论:
Thank you FreddyR!!!! I did this and it actually worked!! too bad I factory reset my phone before doing this. Although I don't have a SD card on it. I did it with my sim card, and it definitely worked! :) Thank you once again!
完成的
This worked!!!!! I tried everything else people suggested & nothing worked! I did not have to actually take out my SD card though ... All I did was erase everything on my SD card... Unmount the SD card to safely remove... Then power off my phone(but did not remove SD card) then did the factory reboot(press the power button & volume up at the same time, a white screen pops up then unpress the power button & a black screen will pop up u will be already highlighted on "factory reboot if u keep pressed on the volume up key then press power button to select reboot)!!!!then turned my phone back on & my camera was working!!! & all my pics were still there so was all my Apps & settings!!!
完成的
Thank u shaela wahl I did what u jst said and it worked!!!!!! I didn't loose anything!!! Everyone who is having this problem please follow this one
完成的
Yeeeessss!!! Thank you so much, that finally did it for me!
完成的
This was the only thing that worked...now im going to wipe it clean so i can put it back in my phone...unfortunately i make lots of videos so i need my SD card...fingers crossed!
完成的
添加一条评论
My friend fixed it for me all though he never told me how he did it exactly he did mention he was fiddling in the settings and enabled my camera. Thats all i know good luck!
这个答案有帮助吗?
得分 1
2条评论:
How about on ZTE grand memo lite. Will it work? Same problems.
完成的
My front camera is showing a purple and green glare on the front screen the back camera shows great
ZTE MAX PRO PHONE
完成的
添加一条评论
Follow these instructions. I just did this to my wife's and hers works like normal now.
1. Open settings
2. Open apps (under device section)
3. Swipe 3 times from right to left (will say disabled at top)
4. Select camera
5. Tap on enable
6. Hold camera on apps screen and place on your main screen page if you desire.
Hope this helps.
这个答案有帮助吗?
得分 1
1条评论:
Did all of this stuff and it still wont work
完成的
添加一条评论
All you have to do is remove your Sim chip turn your phone off place the sims card back in and turn your phone back on and your camera will work again.
这个答案有帮助吗?
得分 1
2条评论:
Just remove your Sims chip turn off your phone and put it back in and turn on your phone and it will work.
完成的
Wes was right. Settings > Camera > All > Clear data. Fixed.
完成的
添加一条评论
Open apps in settings look for camera hit force stop clear data immediately restart phone and you're good
这个答案有帮助吗?
得分 0
添加一条评论
I tried to reboot and it didn't work. Then one comment said clear cache so I longer pressed the camera and slid the icon into the app info then I cleared the cache and the data. Then rebooted my phone just like it said on here and it works now! No lie! Thank you everyone!
这个答案有帮助吗?
得分 0
添加一条评论
"Rebooting" it worked perfectly.....(no factory reset). Turn off the phone, hold the volume up and on/off button together u til u get that black screen, 1st line asks if you want to "reboot" to choose it use the on/off button as (yes,enter)
这个答案有帮助吗?
得分 0
1条评论:
And be sure phone is charged above 20%!
完成的
添加一条评论
With your phone on , press and hold volume down, the back button,and power button for 35 seconds. The phone will go into shut down. Wait for 5 seconds. Press and and hold power to restart. This should resolve camera and led flashlight problems.
这个答案有帮助吗?
得分 0
1条评论:
Nope I tried this and it didn't work I don't think I'm ever getting my camera back
完成的
添加一条评论
OH Boy.....I did all the above and all the above in many forums..got Samsung troubleshoot over a chat factory reset 3 times...safe mode...tried all the cashe deletes data deletes ect...so the only thing that I could figure out was under settings...security....clear all certificates was greyed out so I could not do that...then under security ..trusted credentials..display all certificates I find about 100 certificates and have to disable each one...then I did the hold volumn button with power button together and get the black screen to restart the phone...after 2 weeks and hours of frustration I felt like I had my first baby..cause my camera and my flash was WORKING! Oh joy and bliss
这个答案有帮助吗?
得分 0
添加一条评论
Hold the power button and volume up at the same time. That worked on mine
这个答案有帮助吗?
得分 0
添加一条评论
Turn it off, plug it wait an hour then turn it on .
这个答案有帮助吗?
得分 0
添加一条评论
All you have to do is charge your cellphone over 50% or till full, on ZTE cellphone it has an internal command that automatically disables the flash until it's at or near full power. Mine was at 12% when I was unable to use the flash. When battery was charge at 50% it started working again. Keep in mind that flashlight apps can still light the flash because they operate I dependently from the phone.
这个答案有帮助吗?
得分 0
添加一条评论
10 Second Fix
Go into settings.
Select storage.
Tap SD Card
Scroll to Eject
Accept Eject
Wait 3 seconds
Tap Mount
Have a nice day!
这个答案有帮助吗?
得分 0
添加一条评论
Hold the volume button and the power button at the same time for few seconds.Spreadtrum factory test will display. press "vol. down" key select PCBA sinle test and press "vol.up". Now select "front camera" then press "vol.up". your front camera will work. Now select "Back camera" then press "vol.up". your flash light only work and not the back camera. Everything has been tested. CELKON fools have not come forward. There is general problem with the software corrupted throughout the world of CELKON. But they have not solved. CELKON camera NOT WORKING AFTER DOING ALL with SD without SD. Close CELKON. That is better.
这个答案有帮助吗?
得分 0
添加一条评论
All I had to do was take out my SD card. And it started working. I replaced the SD card. And everything still works. So far anyway. Thanks guys.
这个答案有帮助吗?
得分 0
1条评论:
Go to settings
Change SD from internal to portable
SD card starts formatting
After done, your camera is working!
(**Plese back up your SD files first)
完成的
添加一条评论
press the camera icon for several seconds. then choose"take photos". it works.
这个答案有帮助吗?
得分 0
添加一条评论
If your ZTE ZMax camera isn't working and you're seeing 'Unable to connect to camera' or 'Camera has been disabled because of security policies,' try the following steps:
Restart the Phone: A simple reboot can resolve many camera issues.
Remove and Reinsert the SIM Card: Power off the phone, remove the SIM card, wait a few seconds, reinsert it, and power the phone back on.
Check for Software Updates: Ensure your phone's software is up to date, as updates can fix bugs affecting the camera.
Reset Camera App Settings: Go to Settings > Apps > Camera > Storage and tap 'Clear Data' to reset the app.
Factory Reset: If the above steps don't work, consider performing a factory reset. Remember to back up your data before proceeding.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andy 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 53
过去 30 天: 126
总计 192,317
