跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
Why can't I connect to WiFi?
I can't connect to our wifi. After I click to connect to our WiFi, it takes me to another window. The URL says apple.com and the title of the page is Log In, but the page shows up blank with just an odd line of code at the top. It looks like this.
http://puu.sh/iZLdh/c8415d76c1.jpg
After that the WiFi connection ceases.
The wifi itself is working fine, my sister is using it without problems on her laptop currently so no resetting of the router is needed.
I've restarted the device and reset the network information.
I'm entering the password right.
I'm currently wiping the device clean.
Apple Customer Service was about as stupid as a pile of rocks. "Herrderr it's your WiFi that's the problem because if you wiped it clean it can't be a software issue."
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
I have this problem aswell. It was working fine last night but this morning its come up with the same thing you have
完成的
添加一条评论
2个答案
已选择的解决方案
FOUND THE FIX!!
1.) Go to SETTINGS next to your networks name there's a blue arrow click on that.
2.) Now turn ON auto-join
3.) Turn OFF auto-log in
4.) It Works!
这个答案有帮助吗?
得分 2
1条评论:
Thank you!!!
完成的
添加一条评论
I have this problem too, I saw some people with the same issues on the apple forum but they've been wiped off in the past hour. I think apple has sabotaged older ipods. All the issues occurred in the past few hrs.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
lisacananimate 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 30
过去 30 天: 76
总计 3,745
