跳转到主内容
Released June 2014, identified by model 635.
54 个问题 查看全部
Bad Power Button Connection on Nokia Lumia 635
I can tell that it won't turn on for this reason. If I plug it in, the screen is still on, and it turns on when I get a notification. I've made this work for a bit by extending the time the screen is on but this massively drains my battery. How would I fix this? It seems petty to take into a phone repair place.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
最有帮助的答案
Did your phone get hit or dropped?
The most probable reason for that seems to be related to the inner pressure point connector of the power button (located right at the motherboard). Take it anyways to a technician: He would probably tell you that it needs to replace the motherboard of your phone, as it the integrated connector it's difficult to solder again (or doesn't have the time/skill/part for it).
Hope it works again!
Narmith
这个答案有帮助吗?
得分 1
1条评论:
Narmith!....i have the same problem but I think I dropped it ..how much does it cost to repair it?
完成的
添加一条评论
lumia 635 power baton bord not warking
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
gobstopper2 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 963
