跳转到主内容
型号A1288,闪存容量:8、16及32GB
What to do if the screen is white?
the ipod is dead and the screen is white what do i do to fix it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
hmm - that makes no sense ;-)
is the ipod dead or does it show a white screen??
dead would mean: screen is black and doesn't show anything, doesn't react when you connect it to the computer - it would simply be dead
white screen would mean: the WSOD (white screen of death), the ipod can be switched on but does only show a white screen!
there are a few things you could try
  1. make a hard reset: press and hold the home and the sleep button at the same time until the ipod restarts (should take 10 seconds) - if your lucky - the ipod will work again after the boot process
  2. if the ipod was dropped - it could also be a connection problem - you should need to reseat the lcd connector (if it was dropped and reseating didn#t help, the lcd could also be broken in the upper area - in that case the lcd needs to be replaced)
  3. if the ipod had a fluid damage and shows the white screen, it could be a shorted connection or a toasted lcd controller (that would be the worst thing)
i'm sure that there are other things too that could led to the white screen - but those are the most common issues
这个答案有帮助吗?
得分 4
1条评论:
完成的
添加一条评论
you need to tear apart your itouch and get to the lcd screen. with a multimeter check to see if the fuse on the lcd screen is open.
这个答案有帮助吗?
得分 1
1条评论:
lol - you should tell people where the fuse is when you give them the advise to check it ;-)
完成的
添加一条评论
添加你的答案
amanda 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,454
