跳转到主内容
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
220 个问题 查看全部
Tapping near home button turns off screen and clicks.
I changed my digitizer making sure to follow each step carefully. I got it fully assembled and powered it on. It turns on fine and i checked the screen to make sure there are no dead spots, worked fine. when i tried to bring up the lower short cut menu it wouldn't come up and then i tried pressing the home button but ended up pressing on the edge of the frame and it turned off the screen and made the lock "clicking" sound. I tried tapping on the front surface and i happened again. its only the spot directly to the right of the home button that does that. i took it apart and reassembled it but still same problem. Can it be a defective Digitizer?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Can be from a couple things. Could be the ribbon that holds it in is being put under pressure when you put your finger on it. Can be also your digitizer isn't working. Maybe you pushed it on too hard when you installed it. Start with the easiest thing to test and go from there.
Best of luck!
这个答案有帮助吗?
得分 0
1条评论:
Im having this same issue and can’t seem to find a solution. Any advice out there?
完成的
添加一条评论
I’m having this same issue and can’t seem to find a solution. Any advice out there?
EDIT:
Problem solved!! On the back side of the digitizer there are two very small electronic components just to the right of the home button that were shorting out on the aluminum casing. I found it by using a metal tool (i was previously using plastic) to poke around until i made it happen again.
My solution was to cut a piece of the blue film backing from the adhesive strips and tape it over these parts with clear scotch tape.
I hope this helped somebody! Let us know in the comments.
-B
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rvega95 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 7
总计 310
