跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Phone overheating when camera is on
Hi,
I have a problem with my iPhone 5s. I dropped my iPhone and the screen was cracked. After the drop, my rear camera and flashlight stopped working. I thought if I replace the screen, the camera might start working again but no luck. If I try to turn them on, the top right corner of the phone gets extremely hot and I need to turn my phone off to stop the heat.
Anyone know what might be the problem and how to resolve that?
Thank you.
K.V
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Sometimes on electronics the thermal paste can get dried up. Sometimes it's best to open it up, re-paste the thermal, and put it back together. Although what i think is happening is the camera is stuck on permanently and that is causing the heat ups. Hope that helps!
The camera part on ebay is about 10$.
这个答案有帮助吗?
得分 0
1条评论:
Thanks for your reply. The flashlight is also not working. Do you think when I replace my rear camera, then it all should be OK?
完成的
添加一条评论
The camera and the flash light are correlated parts. If camera stops working, the flashlight doesn't work either. Therefore, fixing camera issue resolves the flash light. You can get the required part here. Check out similar vendors selling the same items at the most competitive price. This will benefit you.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Keiro Vantsi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 7
总计 1,654
