跳转到主内容
加入维修社区 - 创建账户
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
Excessive steam from machine
Why does my machine leak excessive steam from the wand?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
The steam valve seals by way of a hard teflon gasket, and over the years this seal can develop a groove and needs adjusting in order to get it to seal again. Remove the top of the machine and locate the steam valve on the front left side. With the steam valve fully closed, loosen the small hex bolt that holds the black steam valve stop in place and attempt to close the steam valve further. Then re-tighten the hex bolt, fire the machine up and see if it still leaks. If so, you may need to remove the knob/valve assembly and either flip over or replace the teflon seal.
这个答案有帮助吗?
得分 1
1条评论:
It worked. THANKS!
完成的
添加一条评论
添加你的答案
kevin villars 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 250
