跳转到主内容
The drone is a Wi-Fi capable and it's equipped with a built-in HD camera. It is used for taking pictures and filming. Model number: PF722000
Unstable Take-off and crash
Hi, initially when I hit the take-off button the drone used to hover. For some reason now it spins and tilts to the right ...and crash lands
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
3个答案
最有帮助的答案
Verify your helices, My do the same and I change, be attencion on the jelices open in the center and others is not, the close ones maybe put in silver pin above.
Sorry about my english
这个答案有帮助吗?
得分 1
1条评论:
André, o que vc fez pra resolver o seu? O meu não fica mais parado, ele fica andando sozinho...
完成的
添加一条评论
calibrated wrong if the trim is out of wack it will do that
这个答案有帮助吗?
得分 0
1条评论:
How do you fix the trim?
完成的
添加一条评论
Did you ever fix your problem? Dealing with the same thing. I was flying my drone when the prop flew off and now it does not take off and hover at all
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Doberman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 2,313
