Why can't I login? OS X with FileVault enabled
Can't login. Your home folder,which is protected by FileVault, didn't open.it needs to be repaired. To repair and continue logging in click ok. If I do that I get-your unable to log into the user account at this time. Logging in to account failed because an error occurred.
== Update==
Found original box: MacBook Pro 17/2.8/2x2GB/500/SD/AG
3条评论
I'm trying to start up from install disk. Os x 10.6.4. Was using wrong install disk from my old PowerBook G4. Found right disk now trying to get to disk utility.
由 Dan 完成的
MacBook Pro 17" 2.8GHz i7 (Mid-2010)
由 DanJ 完成的
10.6.8 build 10K549 I can't get in past login screen to get Apple info.
由 Dan 完成的
