跳转到主内容
Support for gas-powered and electric golf carts, sometimes referred to as golf cars or club cars after the Club Car Golf Cart brand.
495 个问题 查看全部
1998 electric club car golf cart rear brakes locking up
My husband and I purchased a used 1998 electric club car golf cart and when you step on the brake the rear brakes grab real bad. It almost throws you through the windshield. The man we bought it from (very trustworthy friend) said he had just had the brakes replaced not long before we bought it. When this happens with the brakes, it kicks the brake pedal back up. Do we just need to adjust them or could there be something else going on. My husband and the mechanic we always use for our cars are at their wits end.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
Check for axle twist especially if the cart has a lift kit. Check to see if the U Bolts are tight they often loosen and just need retightened .
这个答案有帮助吗?
得分 1
2条评论:
Check for rear axle twist especially on a cart that has been lifted. The U Bolts loosen up and allow the rear axle to roll adding additional pull on the brake cables when the brakes are applied.
完成的
How does the rear axle “twist" and how do u fix it?
完成的
添加一条评论
If it has a lift kit try tightening the U bolts Mine were loose and fixed it
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cathy 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 47
总计 5,921
