跳转到主内容
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
312 个问题 查看全部
only works with power cord attached
My less than 1year old mac will not work on battery. it only works with the powercord attached. I don't use this much and never keep it on charge all the time
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
If your machine is less than a year old, it's still under warranty. Take it back to your nearest Apple store and make them fix it!
I hope this helps!
这个答案有帮助吗?
得分 2
添加一条评论
The battery on my Macbook Air died completely after about a year and a half. I believe that being fully discharged helped kill it. Word to the wise -- plug the computer in when you get the warning window saying the battery is low; don't wait until the computer conks out on its own.
Incidentally, I used the instructions at ifixit.com to replace the battery ( MacBook Air 型号 A1237 和 A1304 电池更换 ) -- and it was a pretty darn easy fix. The only big challenge is keeping track of all of the screws.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Howard Tanner 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,094
