跳转到主内容
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 个问题 查看全部
问题已关闭
Changing to sshd from hdd in iMac 27 late 2009
I'm planning to change my 1tb seagate hdd to a Seagate Barracuda® 2TB
SATA 6Gb/s (SATA 3.0), 64MB Cache, 7200RPM, 3.5", do you guys think this is a good sshd to change to?
whats the difference from this model sshd and the nand flash models?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
6条评论
You do want to make sure your systems firmware is up to date here and remember the SATA port speed of this system is SATA II (3.0 GB/s) so the drive you get needs to run at this speed or have a way to set it's speed via a jumper.
完成的
can you tell me what is a jumper and direct me to a nice one?
thanks
完成的
The jumper would be on the drive if it has one. Not all drives need a jumper as they are auto sensing of the systems SATA port speed.
完成的
So please Dan sorry I'm such a noob.... But I'm about to get this one Seagate® Desktop SSHD 2TB
SATA 6Gb/s, (SATA 3.0), 64MB Cache, MLC 8GB NAND Flash, 3,5"
Is that going to be ok for my iMac?
完成的
Do I need a heat sensor for that as well ?
完成的
显示更多的1条评论
添加一条评论
2个答案
已选择的解决方案
Basically a SSHD is nothing more than a hard drive with a very deep cache (SSD). The drives hardware manages what should be held in this deep cache depending on how often it is called. So as an example your OS files and maybe some app files. If you constantly reload a given file it too maybe cached.
SSHD's are a good half step as larger SSD's are still quite expensive! A 1TB SSD drive is still over $400 U.S.
Some systems can't support two internal drives (i.e. HD & SSD) so a SSHD is a good option. If your system can support two SATA drives then getting a small sized SSD in conjunction with a standard HD could offer still better performance either as a fused drive (Apple Fusion Drive) or discreetly.
The other option here is a dual drive like Western Digital's Black2 drive. This is really two drives (HD & SSD) in one device. So far they only offer a 2.5" drive and is not very large and is a SATA III (6.0 Gb/s).
Here is the IFIXIT guide to replace your current HD: iMac Intel 27" EMC 2309 and 2374 Hard Drive Replacement.
Update (09/21/2015)
If you are thinking of giving up your optical drive for a second drive this is the IFIXIT guide to follow: Installing iMac Intel 27" EMC 2309 and 2374 Dual Hard Drive and here is the IFIXIT drive carrier: 2.7 mm SATA Optical Bay SATA Hard Drive Enclosure.
Then you could go with a straight SSD in it and a standard HD to replace your current HD. I don't recommend going with a SSHD if you plan on using a SSD with it as most people want to create a Fusion drive set (combining the SSD with the HD as one virtual drive letting the OS manage the file placement). If you do plan on keeping the drives independent then there is no issues.
Update (09/21/2015)
Here is the Apple P/N's for the thermal sensor cables if you go with a different HD or install a SSHD.
  • 922-9223 - Hitachi
  • 922-9224 - Seagate
  • 922-9225 - Western Digital
iMac & Mac mini Dual Drive Enclosure图片
产品
$19.99
iMac Intel 27" EMC 2309 and 2374 硬盘图片
指南
iMac 因特尔 27" EMC 2309 和 2374 硬盘更换
难度:
中等
30 minutes - 1 hour
iMac Intel 27" EMC 2309 and 2374 Dual Drive图片
指南
Installing iMac Intel 27" EMC 2309 and 2374 Dual Drive
难度:
中等
1 - 2 hours
这个答案有帮助吗?
得分 2
1条评论:
One last issue is Yosemite had issues with 3rd party SSD's. With the latest update that problem is now resolved!
完成的
添加一条评论
You've got a iMac that is very upgradeable. I had one of these and looking for speed and reliability i wanted a SSD AND a traditional Hard drive. With these iMacs you can open it up and install BOTH the SSD and your 3.5in HDD with replacing the CD/DVD drive in your imac and installing a hard drive caddy. They allow you to keep a big storage type device like your Seagate drive and use a SSD at the same time. Im sure there is a guide here on iFixit but you can get the jist of it looking on youtube. Just something ive found to be very cool considering Apple products. Look into it. Dedicated SSD's are far better than the SSHD's.
This is the caddy: http://www.amazon.com/SATA-Drive-Caddy-A...
这个答案有帮助吗?
得分 0
4条评论:
Hey there and thanks for ur comment . My question is really if I can add a hybrid sshd Seagate that I mentioned before as the main hdd. I've been reading in many places that for this model iMac I should get the same brand as the one that comes as factory set.... Which is a WD. So I was expecting someone here that really knows about it. I was considering changing the optical drive to a ssd or another hdd with high capacity. But not untill I know for sure what to do with my first problem. Pls help
完成的
@Carlostimon - No, you don't need to replace your current drive with the same brand drive. If you do switch it out you'll need to also switch out the drives thermal sensor cable to match the drive you put in. Sadly, WD doesn't offer a SATA II (3.0 Gb/s) SSHD drive. Here's what the do offer: WD Desktop SSHD. The Seagate SSHD drives has auto sense and will work in your system. Here is the Seagate specs: Seagate Desktop SSHD. Review the SATA speeds they support.
完成的
Hey Dan thanks for ur reply! Which do u think personally I should take, I'm looking for SSHD hybrid of 2gb or more.?
完成的
Storage space is always a difficult question. What is just fine for one person is not enough for the next. You also need to look at your pocketbook and the age of the system here. Older systems days are numbered so putting to much into them may not pay in the long run.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 3,220
