跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 个问题 查看全部
radeon hd 6970m 2gb
Hi! spoiled my video card radeon hd 6970m, under the guarantee given up, I want to replace it with the same but issued for DELL, they are similar in appearance, the question is whether it is possible to install the card, will I have a problem?
1)FOR MAC http://ru.aliexpress.com/item/Genuine-Vi...
2)FOR DELL http://ru.aliexpress.com/item/for-AMD-Mo...
thanks in advance!!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论:
нет! я не опробовал к сожалению(
完成的
English: No! I have not tried unfortunately (
完成的
It doesn't work!! I have tried it buying in the same place. For iMac is twice the price... :(
完成的
添加一条评论
2个答案
It is absolutely possible. You need to be extremely careful handling display while taking apart though.
Make sure that the Display LVDs, Power and Sensor cables are detached carefully. Also make sure that you pull the logic board out gently and without having electrostatic in your body. Once the logic board comes out, the video card is detachable from the logic board slot once the onboard 2 screws and 1 tail screw is removed. The video chip is secured by 4 screws. Get them out, clean the leftover thermal grease, place the chip, put the new thermal grease on it and secure it carefully. Reassemble your Mac very carefully. This is quite a fun and risky at the same time. That's it.
这个答案有帮助吗?
得分 0
添加一条评论
Musa, have you tried this? I am considering doing the same thing. I did hear that the location of the screws of the heatsink are a bit different though. But maybe you didn't have a problem or found a workaround?
这个答案有帮助吗?
得分 0
2条评论:
нет! не опробовал!
完成的
English: No! not tested!
完成的
添加一条评论
添加你的答案
Musa 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 2,713
