跳转到主内容
Eighth generation of the Mazda Protege.
49 个问题 查看全部
What are the symptoms of a weak ignition coil?
Why does my 1999 Mazda protege 1.6 hesitate to go when i accelerate immediately after any immediate stop? Is it something to do with ignition coil? I did hear a spark noise from the ignition coil area when i checked. Please advice me.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Thank you guys... Coils and new NGK iridium spark plugs on its way.
完成的
添加一条评论
2个答案
已选择的解决方案
The symptoms of a bad coil are misfire or backfire,engine stalling, hard starting and smelling fuel while trying to start, bad fuel mileage and not starting at all. If you are hearing a sparking coming from your coil its more apt to be bad ignition wires .I would start by checking plug wires and boots Hope this helps
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
Weak coil will cause miss firing and hesitation.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Vishnu 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 17
总计 3,424
