跳转到主内容
The Nokia Lumia 720 is a Windows Phone 8 device manufactured by Nokia. It was released in April 2013.
Why my touch is not working?
i reset my lumia 720 some days ago after this when the phone is open then i see my below 1 inch touch is not working. i changed the touch but same problem again occur.
Plz solve my problem i m really worried about this problem
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
5条评论
i guess your new touchpad also faulty
完成的
sir,
is it possible that new touch can faulty???
完成的
Manish, Manufacturing faults can be happen, check with another touch pad and see what's gong on
完成的
sir my back key nad home key and search key not working nokia lumiya 720 4 day ago i have change folder its fine working but 4 day after tuch key back nd hom nd etc not working ....:(
完成的
Tanvi jain, Backup all data and reset the phone to factory default, after resetting same fault observed, it's better to check with new touchpad. most of cases like you mentioned coming from touchpad fault, such as drop or liquid damages
完成的
添加一条评论
2个答案
最有帮助的答案
Just check connector of your digitizer again - use magnifying glass and check if all pins are intact ( on both sides - Motherboard and cable). Clean with Alcohol ( not Beer or Whiskey) and carefully make a connection. You should hear and feel CLICK sensation if everything is ok
这个答案有帮助吗?
得分 1
添加一条评论
yesterday my lumia phone touch working very good but...
today it cant work....
my phone touch is not damaged or cracked its completly good
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Manish 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 1,766
