跳转到主内容
The third generation of Galaxy Tab including a 7.0, 8.0 and 10.1 inch display versions, as well as the Galaxy Tab 3 Lite 7.0. Released in July 2013.
443 个问题 查看全部
问题已关闭
Charging in very long hours and battery exhausts very soon
Hi,
I have Samsung Galaxy Tab 3, Model SM-T211 with Android version 4.4.2, Kernel Version 3.4.5-4496770.
I had issue with my tab was it used to take long hours to get battery charged and used to exhaust the battery within 2-3 hours. It used to turn off when the battery was 40-50% or sometimes at 60% too. I have changed the battery but it still is taking very long hours to get battery charged full. Last time I started charging at 1600hrs and it charged completely at 0900hrs in the next morning (about 25 hours). Please help me to resolve this problem.
Ashwani
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Either the battery is not charged with a powerful charger, so it will take long to charge.
Or the device constantly runs with high CPU load, then you should use a CPU monitor App to verify that first.
Last possibility is a old or damaged battery, which then needs replacement.
I had this problem on my Galaxy tab 2 also, because a Program was constantly using up the CPU.
这个答案有帮助吗?
得分 1
添加一条评论
Thanks a lot for your quick and very helpful response. Can you please help a bit more by adding how to manage CPU load and how to verify the App.
这个答案有帮助吗?
得分 0
1条评论:
There are several Apps to check the CPU load for Android in the PlayStore.
For example https://play.google.com/store/apps/detai...
This will show you any process that is constantly using up too much CPU (if that is the case for you)
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 6
总计 913
