跳转到主内容
加入维修社区 - 创建账户
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
Does apple reprograms touch id?
For example, my touch id stops working and I'm out of warranty coverage, does apple replaces the part and repograms the phone to the touch id sensor?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
6个答案
已选择的解决方案
Yes, if they replace the display, the Touch ID button has to be replaced as well, they must have a way to reprogram it.
From what I know, they will replace the display assembly (the entire front half of the phone) altogether if:
the display is broken,
the top sensors does not work,
the receiver still does not work after replacing just the receiver,
Home button/Touch ID does not work.
The cost for OOW display replacement is around $100, if replacing the display doesn't resolve the issue, they will replace the phone.
这个答案有帮助吗?
得分 11
1条评论:
How does the iPhone know that you change different home key
Is it from the ic’s on home button?
完成的
添加一条评论
Ex-Genius here...
Apple replace the entire display for Touch ID related issues.
They use a "calibration" machine that pairs the new Touch ID to the logic board processor.
这个答案有帮助吗?
得分 9
16条评论:
An actual custom "machine" instead of a generic computer that talks to the phone through USB?
完成的
Yes that's correct they have several of the machines which the iPhone will sit inside and go through various tests and meanwhile it will pair Touch ID
完成的
I did see pictures of those things. It requires Apple internal servers to authorize pairing is it right?
完成的
Partially yes, it also requires Apple specific applications and processes to run.
With talks of Touch ID being integrated into the next generation displays it leaves us tech people in a bad position. Hopefully someone finds a simple software solution for pairing...
完成的
This machine is probably just a well-staged cover up. You mean to tell me that there is a machine that's only purpose in life is to pair and calibrate iphones? No. I singlehandedly (yeah, that's right) discovered a way to pair a touch id button, and although it's still just theoretical now, it absolutely does NOT require a giant machine. And furthermore, it can theoretically be done without any top secret machines at all. This machine is just there so geniuses can pair iphones without learning about the ACTUAL pairing process, and leaking it to the public. Yes, I must mention, my own pairing procedure is theoretical at this point, and I still need some more knowledge about the details to be able to achieve success.
完成的
显示更多的11条评论
添加一条评论
can the chip on the touch id cable that stores this key be reprogrammed? is it an eeprom? a uveprom? or is it non-reprogrammable, and simply a rom? I intend to figure this out.
这个答案有帮助吗?
得分 1
12条评论:
but even if you can reprogram it, how would you get the key that the device has thats matched to it?
完成的
Is it not possible to extract this data from the previous sensor and than copy it to a new one? Trick the phone into thinking it's still the same button... My touch-id still works, but the button itself doesn't work anymore.. So i have to choose between a button or the touch-id...
完成的
Not possible, that's why it's called security.
完成的
IS it so much more secure than other devices? For example the Huawei P9, where you can swap the finerprintsensor just bij removing the rearhousing...
完成的
A Huawei is not the same as the iPhone! It's like comparing apples to kumquats.
完成的
显示更多的7条评论
添加一条评论
Can apple fix touch id on an iphone 8 plus ?
这个答案有帮助吗?
得分 1
添加一条评论
When they replace the whole assembly.
they transfer the Touch ID over from your old phone.
thats why the design of the Touch ID is so easy to remove.
Because the monkeys at apple need to transfer it over, yet somehow they manage to rip it.
if that happens they will have to replace the phone for you for free!
The Touch ID is serial coded to the logicboard. apple does this out of spike because they hate DIYers.
这个答案有帮助吗?
得分 0
4条评论:
You have anything to back that up?
When they repair home button issues, they replace the display, proving they can reprogram the button, plain and simple.
Also the key provisioning is for security, it has nothing to do with DIYers.
完成的
im not saying apple can not reprogram the Touch ID
im saying thats not something what the genius bar when you have a bad Touch ID
as a former apple employee with many close friends still employed with apple im speaking from experience.
And Tom, please enlightenment me with your vast expertise on what security reason does apple have to lock the Touch ID to the phone. The Touch ID is simply a biometric reader, the fingerprints are store locally on your phone. How does replace the the biometric sensor with an aftermarket or even an original biometric sensor a security threat.
完成的
Security is a little more complicated than you think. The sensor is "just" a sensor correct, however the sensor has to send the data to the phone securely and mitigate the damage if one hack is successful. Hence the data line has to be encrypted with a session-specific key, generated from a device-specific master key provisioned in the factory. The master key should not be accessible to the outside world and the provisioning process should not be able to be triggered by just anyone (to prevent wiretapping the provisioning to obtain the new master key). In this way Apple can ensure chip-to-chip security, No system or user data travels on a visible bus unencrypted, preventing anyone performing attacks using software/hardware tapping. Unless they break in the chip, dump the keys and burn them into a new chip.
I'm not saying they won't transfer the button but from what I know as of now they don't do that. And they can repair Touch ID/button issues without giving you a new phone prove that they can reprogram it.
完成的
There is no win or lose because this is not a fight. Sunny said Apple might be repairing the display without reprogramming Touch ID, which is good because they can offload the repair to AASPs without giving them the ability to reprogram (for security). I'm saying they can reprogram because they have done that. It's just different points.
完成的
添加一条评论
Apple Tech with iPhone home button reprogrammer.
这个答案有帮助吗?
得分 0
1条评论:
do you reprogramme ipad mini 3 home button. i have the button and flex but its snapped
完成的
添加一条评论
添加你的答案
Osvaldo Banda 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 34
过去 30 天: 110
总计 49,951
