跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2376 个问题 查看全部
问题已关闭
Why my iPhone boots and screen starts to be red?
Hi,
my power/lock button stopped worked today, so I opened the iphone and replaced it, when I boot the screen is black with backlight on and then starts be red but only on left side of the screen. Maybe I damage the connector of the screen?
During the assembly I lost about 2 screws
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hey Roberto, this usually happens when all of the screws aren't in the correct place for the metal part which is usually found covering the digitizer. Please redo it make sure the screws are in the appropriate place because you can damage the logic board by doing this. A common mistake that can cause this is that the longer screw is put in the incorrect spot or missing screws.
-Let me know how it goes.
-Please accept this answer if it answered the question.
这个答案有帮助吗?
得分 1
2条评论:
I think I need to buy a new set of screws from ebay, thanks a lot for the answer, I will update
完成的
If this helped in any way please accept this as the answer and thank you.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 66
