Assembling after Logic Board Replacement
Hi,
Im replacing logic board in an iPad Mini 1. Originally the board is stick with sort of metal tissue pieces to the bottom of the device, I suspect metal is used deliberately :).
The problem is those metal things is quite difficult to re-use, what would you do? Metal scotch is quite expensive and using foil just looks wrong...
2条评论
Another question is if it must be electrically conductive or just heat conductive...
由 Maaaah 完成的
Do you think if http://www.aliexpress.com/snapshot/67551... could be suitable?
由 Maaaah 完成的
