跳转到主内容
Repair guides and support for the Canon Speedlite 430EX II external flash assembly.
11 个问题 查看全部
Why isnt it turning on?
I checked the batts, even tried new ones and still it wont turn on. Is there some explanation for this? I really confusing and i really would like to know the problem before i buy a new one
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
1个答案
已选择的解决方案
Check the battery contacts for corrosion - typewriter eraser pencils are ideal for polishing the contacts. The ON/OFF switch can fail - try pushing down as you slide the switch. The switch can be repaired for less than the cost of a new flashgun, as long as you don't go to Canon that is...
这个答案有帮助吗?
得分 11
16条评论:
Mine did the same thing, and it was battery corrosion - only a tiny bit, barely noticeable, but enough to break the contact. Rubbed it with the eraser end of a pencil, and put the battery back in and it worked. I'll now get some rubbing alcohol and clean it properly.
完成的
Was about to replace my $300 Speedlite 430EX II, came here, checked the contacts in the battery compartment and boom! Quick scrape and all good.
完成的
Thank you guys, had the exact same of the battery compartment with the corrosion. Glad I found this.
完成的
On question guys. my problem seems similar, but the thing is that afer the corrosion because of the old bateries, the switch button to turn on is really hard, its like stuck and I dont want to force it to breack it. Did you have the same issue? Or your issue was that you can switch the button to on but the flash did not turn it on? Thanks
完成的
Super valued tip!! Using the eraser made it work again!!
完成的
显示更多的11条评论
添加一条评论
添加你的答案
itodak 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 94
总计 11,911
