跳转到主内容
Released June 2014, identified by model 635.
55 个问题 查看全部
Why does my phone always turn off randomly
My phone always randomly turns off, I would be texting someone and then it would (sometimes) flash and then turn off and its really annoying me, and sometimes when this happens my phone will be at 50% 60% etc and the phone will say its dead... Plz someone help me as I don't have a clue what's going on?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
MOST probably: It would seem the battery is damaged and needs to be replaced (did you dropped your phone?). Could you ask a friend for a temporary battery swap to check this, or buy a new one.
Optional: Also, consider doing a factory state formatting, this could solve not only this issue, but make your phone faster (it "refreshes" the phone), but take precaution with your data (remove the SD card!) before that and copy all your contacts to your email provider account (meaning, do not have only one copy of the contact, as the formatting will erase your personal data on the phone), write them on an office excel sheet or paper if necessary.
Hope it serves you.
Narmith
这个答案有帮助吗?
得分 0
1条评论:
Thank you and I did do a battery swap however all that happened is my phone turned on but the screen went pure blue and stayed pure blue and yes I did recently drop this ??
完成的
添加一条评论
buy a new phone.....
这个答案有帮助吗?
得分 0
添加一条评论
Mine switches on and off and then it takes a couple days tell it switches back on
这个答案有帮助吗?
得分 0
1条评论:
so it did turn on aagain and continue working normally?
完成的
添加一条评论
添加你的答案
josh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 3,831
