跳转到主内容
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
How to clean dust from inside system
Hi,
I have a Mid 2010 27 inch iMac model 11,3. It's now been in use for four years. If this were one of the old tower PC's I would have already opened it several times to clean all the dust out of it. Is there somewhere I can learn how to do that on the iMac? I ask because if I watch Netflix I have noticed that the top of the back gets very hot.
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hey mate, this manual should help you out:
http://tim.id.au/laptops/apple/imac/imac...
Also as a note, I'd remove and check the fans for derbies (such as hair) in its assembly
Hope it helps.
这个答案有帮助吗?
得分 4
4条评论:
Thanks Zakk. This is great.
Appreciated!
完成的
Dude, zakk; you're the man. Thank you so much. This is going to be super helpful. I have an iMac 27 2011 model but I'm assuming most things should be similar. Wouldn't you say?
完成的
Hey J.w. sorry mate, I only just realised you'd commented now. Yer it should pretty much be the same thing. If you get stuck, just comment again.
完成的
Does anyone know the shortcut buttons to expel dust using fans.. i've seen it once but cant remember
完成的
添加一条评论
添加你的答案
MTek 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 10
总计 24,307
