跳转到主内容
2014年12月发布的由三星为亚洲市场推出的安卓智能手机,已知有很多型号。
Why my phone cannot turn off?
y phone was suddenly hung-up when I open my email. I press long press to turn off but it doesn't work. It will not turn-off. How can I solve this one? I try to recharge my phone, it doesn't work also.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 21
28条评论
holding the down volume button and the power button at the same time till the phone vibrates should restart it. if you have it plugged in charging and do this it turns the phone off
完成的
That was a fantastic clue. works perfect!. Thank You Dude.
完成的
Wow that really helped me thank you very much
完成的
worked perfectly. thanks much!!!
完成的
Amazing advice! Nothing else worked but this did. Thank you :)
完成的
显示更多的23条评论
添加一条评论
4个答案
已选择的解决方案
Press and hold the Volume down and the Power buttons. When the phone reboots, release them.
Regards.
这个答案有帮助吗?
得分 33
21条评论:
Dat was really helpful. ..thanks!
完成的
its working thank you so much
完成的
its good idea..... thank u .....
完成的
good job...... i really like u......
完成的
it's work... thanks
完成的
显示更多的16条评论
添加一条评论
You could remove the battery and this will kill the phone and hope it boots properly when it restarts once you put the battery back in. Hope this helps and good luck
这个答案有帮助吗?
得分 3
2条评论:
in samsung galaxy a5, you cannot remove the battery since the battery is built in.
完成的
Many, many thanks
完成的
添加一条评论
unplug Charger before Turning off ,,
it turns off and doesn't reboot ,,
When it's already switched off..you can Plug in the charger and it won't turn on..
Works for me Samsung Galaxy j7 OS 6.0.1
这个答案有帮助吗?
得分 0
添加一条评论
Hello .. I forgot my lock pattern and when I try to hard reset it .. won't let me turn it off .. it wants the lock pattern in order to be turned off but I don't remember the pattern .. so .. no hard reset, no nothing .
这个答案有帮助吗?
得分 0
1条评论:
Thankyou so much. Totally worked. Only way to power off / shut down your malfunction samsung j 7 prime phone or device. Power & volume - key while its plugged in to charger. Or else it only restarts.
I was so lost, i felt the phone had malfunctions.
Thankyou so much
完成的
添加一条评论
添加你的答案
Billy495 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 13
过去 30 天: 48
总计 60,237
