跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
299 个问题 查看全部
Suction cup won't stick?
Hello, I am attempting to repair my iPad Air Gen 1, and the suction cup won't stick enough to pull up the adhesive. It's cracked so badly (spiderwebbed) that without the tape, the cup only cracks the screen further.
Any suggestions? Thanks very much.
Cody
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
I usually apply transparent tape all over the broken areas.
Nonetheless, the suction cup will still not hold. You just have to do without it. Lift the edges of the digitizer using a thin tool such as the iSesamo then insert a guitar pick or credit card and run it along the edges while watching out for the flat cables and antennas. Follow iFixit's guide and you'll see where they're located and what to watch out for.
这个答案有帮助吗?
得分 4
添加一条评论
Lots of heat, iSesamo, and patience.
Take your time getting all the glass up, be careful around the connectors. Airs are a pretty straight forward screen replacement if you take your time. Heat an area, use the iSesamo to pry up the glass, move to the next area. Take it an inch at a time. Once you get the glass up, use Goo Gone and IPA to get the adhesive off.
Good luck!
这个答案有帮助吗?
得分 2
添加一条评论
Follow the step by step instructions on here very carefully. You are going to need some heat to loosen the adhesive and something to jimmy between the glass and frame to lift the glass.
I also recommend watching videos on you tube on how this is done. I'm thinking that this may be your first ipad repair so be patient and careful. Things can escalate quickly if you aren't ...
这个答案有帮助吗?
得分 0
添加一条评论
Other answers here are spot on. Usually some clear packing tape will do the trick though.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
morganbaritone 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 12
总计 1,751
