跳转到主内容
华硕生产的上网本的维修和支持指南,包括Eee PC产品系列。
171 个问题 查看全部
Can I upgrade my Asus Eee PC 1015cx RAM?
My girlfriend's notebook pc only has 1Gb RAM and runs really slowly. I was wondering if a RAM upgrade is as straight forward as my Macbook was?
Any pointers?
Update
Well, i just found out that this model is the 1015cx, without the RAM slot. And apparently only has one card. It comes with 1Gb RAM and sholud be upgradable to 2gb.
Not sure about opening it up and getting to it though, can't find any guides. There are four screws under the removable battery, I may try that.
Have a dig around. Anybody know?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
No, the device is not upgradable and the Asus Eepc 1015CX don't have the removable RAM slot , and it is fixed to the motherboard. We can't upgrade to the 2GB RAM. I fully opened the netbook , and don't seen the RAM module to replace.
完成的
Same here asus Eee pc 1015 is not upgraded to 2gb ram it has only one slot and ram fixed inside the motherboard.. I think that there are two types in asus Eee pc first 1015cx BLK024 it was upgraded to 2 gb ram and two slots but the second one is the 1015cx BLK019 it has only one slot and not upgraded to 2 gb.. In my laptop this Problem appear ... Please help.. Upgrade to 2 gb ram any alternative way?
完成的
yesss, can you buy another netbook.
完成的
添加一条评论
1个答案
已选择的解决方案
Yes, the RAM is upgradable. There is a panel that can be removed that is located on the bottom of the computer situated next to the Windows Product Key tag. It uses DDR3 PC3-12800 RAM with two slots available. Each slot can hold a maximum of 1 GB, so you can upgrade to 2GB. The RAM modules can be changed out in under 5 minutes.
这个答案有帮助吗?
得分 2
4条评论:
Thanks jkm. And if it were pc3 8500s that I took out of a macbook, could that work? Would there be an improvement?
Just conveniwnce really as I have them just sitting here.
Please excuse the novice questions, I really have no idea and rely heavily on ifixit and Google.
完成的
PC3-8500 should work. It has a slower transfer speed than PC3-12800, but shouldn't make a noticeable difference in the machine you will be using. And always feel free to ask question. It's what we are hear for.
完成的
I would also mention, since the intention is speed boosting, check for useless programs running in the background.
完成的
Yes, thanks. i found a couple of instructional videos on how to do just that!
In fact, the pc in question (1015cx) has the option to convert some of the HD storage into RAM! I guess that's why they did away with the easy access slots.
Anyway, it is a bit faster now. More ram and less crap. I am becoming a geek, and I like it.
完成的
添加一条评论
添加你的答案
Simon G 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 23
总计 11,110
