跳转到主内容
How to replace a broken iSight Cam cable?
The logic board connection of the iSight Cam stripped and is stuck on the logic board. I have the entire WIFI Bluetooth iSight Cam and Antenna apparatus and could replace the whole thing but the only piece that is broken is the one end of the iSight Cam.
I know I can replace the entire apparatus by taking the screen off but that would be my last resort because it is so labor intensive and I would not want to screw it up. Is there a way to only fix the one end of the iSight Cam cable? Strip and solder the connection? Any advice would be greatly appreciated.
Eventually want to sell the computer but this is one of things in the way right now. Thank you for your help.
Garrett
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
I feel ya man, any luck?
完成的
Smooth comment dude! ( in regards to a deleted comment)
完成的
I ended up replacing the entire cable set. So taking off the display and dealing with the camera cable that way.
完成的
Good option glad you were able to avoid a whole different display. Like I said I tried that even with another technician working under a stereo microscope it was virtually impossible.
完成的
添加一条评论
1个答案
已选择的解决方案
Not No but Hek NO I tried this for a shop that was in a pinch the wire strands are 2 type the inner is FINE wire that if all are'nt soldered together it won't work and they are so small your patience will run out, seriously the only way is another whole display (easiest) or the pull the glass method.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Garrett Andrews 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,823
