跳转到主内容
苹果订单编号为MC007LL/A / 27" 2560x1440 分辨率的显示器。
Backlight LCD turns off + Buzzin Noise
Hi there,
my Apple Cinema Display 27" (no more warranty) got some problems with its backlight and I'm not quite sure whether its the logic board or the power supply..
It works for a few minutes, but than it randomly turns down the backlight of the LCD. There is still a picture, that can be seen e.g. at direct sunlight. So the LCD itself should work fine!
I can speed up this more or less random process by in- or decreasing the brightness.
If i disconnect the display from power and reconnect it, it works again for some minutes. Then, same procedure...
There is also a buzzing noise coming from "inside" which gets louder the brighter the LCD is but doesn't really stop when the backlight turned down again.
For me this buzzing noise sounds like a damaged transformer or some other power supply problems... but I'm not sure...
What I'm sure is, that these two problems have the same source and hopefully will have the same solution.
I already tried the things listed in the Apple Technician Guide and the ones on the internet...
What do you think? I thought I'll ask you for some advice befor ordering some parts like new power supply or new logicboard..
Thank you! :-)
Update
Alright guys... I replaced to PSU. Nothing changed..
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
3个答案
最有帮助的答案
Had the same issue a month ago. Buzzing all the time and increasing the brightness made it worse.
Took it to the Apple Store and they replaced the psu for $129 Canadian. You have to make sure it's the new version of the power supply. Problem was fixed. No more buzzing.
这个答案有帮助吗?
得分 2
添加一条评论
Hi Alex!!
Well... that looks like light at the end of the tunnel...
I ordered this part... do you know the part no?`
http://www.cdx.de/store/products/APPLE-E...
aaaaand.. can I use a thunderbolt display psu? this one should be newer?
thank you!!
这个答案有帮助吗?
得分 1
1条评论:
Yes the thunderbolt one should work without fail. The internals of the cinema display and the thunderbolt display are identical (with the exception of the three extra ports at the rear).
looking at my receipt from the apple store, the part that they provided was 661-6048. this cooresponds to the newer PSU.
I've read a lot of people have the same buzzing issue - to the point that I think it should be considered a defect and covered by apple. oh well. it's an easy fix.
完成的
添加一条评论
Hello! I have exactly the same problem, too,
when 100 brightness motherboard(!) buzzing
I disasambly montior, check the power supply 24 Volt, all ok
I replaced the motherboard and did not help, I think the problem is somewhere in LSD but where?
I do not know :(
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mo Vaillant 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 11
总计 2,787
