Toshiba C55D-A5344 Customer has had a child put bios "boot password"
Bios "Boot password" is present on system.
Looking for the Jumpers on this particular model, Windows 8.1 system. Thanks in advance for any help.
Decided to try once again, I had suspected Jumper labeled B500 was the culprit and in an older iteration of the same type of problem I had remembered that just shorting the two pins was not enough but rather to short from a jumper pad to the -Neg solder joint on the RAM mount... VOILA! Here is a picture of the motherboard and the two pins to jump... You're welcome!!
这个答案有帮助吗?
Gracias amigo tenia ese problema y gracias a ti lo solucione, funciono en el segundo intento y quedo sin contraseña la bios (Toshiba satellite C55D-A5201)
hi saiber,
what did you use to jump these 2 points?
这个答案有帮助吗?
I used a paperclip, you can either use a paperclip or a short piece of wire. It's a bit tricky to hold it while powering it on but totally doable. If you have someone who can power it on while you hold it then it will be a bit easier. Good luck!
If this helps you then please vote for my answer. Have a good day!
I just tried this on a C55-A5105 and I cannot get it to work. I was jumping just the B500 first and then tried connecting one or both of those pins to the pad next to the memory, but the password keeps coming up. I gave up and ordered a replacement motherboard. Stupid computers.
My laptop plise rest sisetem boot
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 7
总计 954
