跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
iPhone Not Fully Loading to Home Screen
My iPhone won't startup. It shows the white screen with the black Apple logo for three minutes or so, then turns off. When I hit the power button, it tries to startup again, with the same white screen + black logo. Then two minutes later, turns off again. I tried holding the power + home buttons to restart, same result.
It just doesn't fully load. Nothing unordinary happened before this. It wasn't dropped or anything like that.
Any suggestions would be highly appreciated. Thanks in advance.
EDIT: I haven't had a chance to back up the phone in a while, so any solution that doesn't involve restoring from a backup would be highly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
connect the Phone with computer. press and homebutton and power key. when Apple LOGO show up, immediately release the power button and continue holding the HOME button until the phone shows a data cable link iTunes icon. then open iTunes icon on your computer, it will show links to be restored on an iPhone, click recovery point or restore the system you want to update.
http://www.aliexpress.com/store/product/...
这个答案有帮助吗?
得分 1
1条评论:
Thanks for the answer! I actually haven't had a chance to back it up in a while, so any solution that doesn't require me to reset it would be highly appreciated.
完成的
添加一条评论
添加你的答案
flavabrwn 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 100
