跳转到主内容
Panasonic released the CF-29 on January 1, 2004. It was designed to survive the harshest environments US Armed Forces, service personnel, and enthusiasts could throw at it. The Black Hawk CF-29 was released in 2009.
17 个问题 查看全部
Why is my hdd not booting or showing up?
I have a used Panasonic CF-29. It came with a SATA upgrade and a 80GB hdd. A couple weeks later it stopped booting saying "Operating System Not Present" and the bios wouldn't show anything under Master IDE so I thought the HDD had died. I swapped in a small SSD (128GB) and installed Ubuntu from a live-usb. EXACTLY the same thing happened "Operating System Not Found"
I've traded the SATA adapter, ditto on both drives.
The weirdest part is that no hdd ever shows up in the bios but will be visible later as a partitioned disk when I view it with Parted in Ubuntu. I can format and install Ubuntu to the disk but upon rebooting the same error appears.
Any ideas what could possibly be going wrong?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Don't spend any more money on a CF-29, it's not worth it.
完成的
添加一条评论
1个答案
最有帮助的答案
Change the hard disk legacy mode in you BIOS and reboot the system. try to install OS with Bootable Disk
这个答案有帮助吗?
得分 2
2条评论:
I'm not seeing a hdd legacy mode. Does this bios have a hidden advanced menu/mode like I've seen in other bios'?
完成的
Have you tried to update BIOS?
完成的
添加一条评论
添加你的答案
Kris Jensen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 1,873
