跳转到主内容
The Canon EOS 7D was Canon's first high end professional camera with an APS-C crop sensor.
51 个问题 查看全部
Frames per second are slowing down... Repair?
I have a Canon 7D that I use primarily for sports photography, so the multiple frames per second feature has been used a LOT. I have noticed that it is skipping or slowing down. Where one press of the shutter used to result in 7 shots in a row, now there is a break and they are spaced differently. I don't think I have changed an internal setting to get this result (although I will check).
Is there a way to repair that particular feature with good result? I photograph horses, dogs, humans in sport, so often track and take multiple images.
MFA
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
hello MFA,
The fault can be occur due to bad memory module. Change the memory (Flash) card and shoot. it should work.
这个答案有帮助吗?
得分 0
添加一条评论
Note that the 7D will slow down considerably in bad lighting situations! This is independent of your shutter speed and aperture settings! To check, use with lens cap on: fps goes down to approx. 3/s. Point at a lamp or use in daylight: fps goes back to 7/s.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
MFA 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 122
