跳转到主内容
Android 4.0 tablet for children/ blue back cover and white face/ released 2012
26 个问题 查看全部
How can I fix the charger piece on my Kurio
I need to know how to fix the charger piece on my Kurio
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
添加一条评论
4个答案
最有帮助的答案
I have successfully replaced the micro USB connector on a Kurio tablet and documented the process here: Repairing Kurio Tablet Micro USB Connector (charging port). However, as Miles noted, this is a very difficult repair, so I would not recommend trying it unless you are comfortable with soldering at fine pitches. Simply replacing the mainboard with a new one from eBay would be significantly easier.
这个答案有帮助吗?
得分 1
添加一条评论
The charger piece is chipped can u please help me fix it on my kurio 7 s tablet
这个答案有帮助吗?
得分 1
添加一条评论
Hi from the pictures i can find of the motherboard it looks like the charging jack is soldering to the motherboard and to replace it would require a new one to be soldering on. I was unable to find a replacement jack so one would need to be pulled off another board. This will require someone fairly skilled in soldering to fix it. And unless the tablet has super important data on it i would either recommend buying a new tablet or one that uses a much more standard jack for charging such as micro usb on a nexus 7 or 8.
这个答案有帮助吗?
得分 0
添加一条评论
Kurio charging port Bent
这个答案有帮助吗?
得分 0
1条评论:
Good and helpful
完成的
添加一条评论
添加你的答案
Shermaine Maxwell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 3,287
